A Farmall Rebuild
Posted by Joe in Tennessee on November 02, 2006 at 14:02:55 from (207.162.166.103):
The new sleeve and piston kit ordered from this site for my A arrived today. The sleeves do fit and they install much easier than the old ones came out. But the new seal ring is a fat O ring. The old seal was square edged with a near square cross section.
My old pistons are cast iron, flat top, and have 4 rings. The new ones are aluminum, flat top, and have 3 rings. The new ones have a V shaped notch on top but does not have any labeling that I can find. The old pistons do not have a notch. I assume the notch goes toward the front of the engine. Is this correct? Is there another purpose for the notch?
If/when I do this again is there a source for new cast iron pistons instead of aluminum?
Thanks.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
