Re: 113/123 governer
Posted by gene bender on November 03, 2006 at 02:41:32 from (67.55.226.214):
In Reply to: Re: 113/123 governer posted by banjo on November 02, 2006 at 20:23:35:
is the input shaft worn and sloppy as that makes quite a difference they can be rebushed then throttle response will be correct. Just bore out the hole and install a 5/8X1/2 brass bushing mite have to trim the length a little after installing.
