Re: Sup H live Hyd.
Posted by Nat 2 on November 03, 2006 at 06:00:01 from (64.80.108.53):
In Reply to: Sup H live Hyd. posted by vally farm on November 02, 2006 at 21:38:28:
The pump should fit okay, but the valves and reservoir won't fit without some radical modifications to the Super H.
On a 300, the reservoir and valves are also the steering pedestal. On an H, the fuel tank is in the way of mounting the 300's pedestal on the tractor. You're much better off with an off-the-shelf hydraulic valve and a simple tank reservoir mounted up under the gas tank.
A Stage II's reservoir is mounted up in front of the belt pulley. There's room for a couple gallons of reservoir up there without having to remove the pulley drive.
