Sup H live Hyd.
Posted by vally farm on November 02, 2006 at 21:38:28 from (207.69.137.15):
I've got a Super H stage 1 that is a real bear, but i blew out the belly pump years ago, and am really starting to mis 'em. I've also got a 300 with a ripped up tranny. I'd like to move the hyds over to the Super H and was wondering if the controls and resevoir would fit (300 has a T/A) or would it be easier to pull the belt pulley off the H and just use a reg control valve and slide a hyd tank under the gas tank...OR would you recomend bolting up a new hyd pump of the crank? Any Ideas would be welcome. Mike
