Re: My M does not start HELP!!!!!!!!!!
Posted by Nat 2 on November 04, 2006 at 17:01:50 from (69.204.107.149):
In Reply to: My M does not start HELP!!!!!!!!!! posted by Gebhardt on November 04, 2006 at 16:11:54:
1. The type of ground DOES NOT MATTER, especially if you're just trying to start the tractor, as long as it is a good ground. Since the tractor turns over with the starter motor, you have a good enough ground.
2. Pulling the tractor is a waste of time if you have no spark.
3. Cranking the tractor is a waste of time if you have no spark.
If you are not getting spark, and all your ignition parts are new, AND THEY ARE INSTALLED AND ADJUSTED PROPERLY (very important!!), then you cannot be getting electricity to the coil.
Get yourself a multimeter and set it on Volts. Turn the ignition on. Touch the red probe to the terminal on the coil. Touch the black probe to a clean spot on the tractor's frame. You should see a voltage reading, either 6 Volts or 12 Volts depending on the battery.
