Re: Hydraulics on old Farmall A: common?
Posted by LenRahilly on November 06, 2006 at 12:58:27 from (24.50.99.60):
In Reply to: Hydraulics on old Farmall A: common? posted by DennisT on November 06, 2006 at 11:44:15:
The Farmall A came out with a PNEUMATIC lift. The EXHAUST was diverted into a huge cylinder that lifted the implement. I have heard that eventually the exhaust corroded this mechanism. The one advantage of this system over the conventional lifts of that time (some mechanical, as on F-20 and Oliver, some hydraulic, as on F-12)is that the lift could be worked even with the clutch disengaged. Most of the other power lifts from the 30s and early 40s operated off the transmission or PTO drive, and so, if the clutch was disengaged (at the end of a row of corn, for example), your lift went dead. If you wanted to come up very close to a fence, you had to shift to neutral, engage the clutch, lift the implement, shift back into gear before moving on. You COULD lift the implement on the go if you had room before turning. One of the problems with this plan is that you needed the engine running pretty fast to get some pump pressure for a quick lift; this meant you could run into the fence if you weren't quick about your turn. Independent hydraulics, driven off the engine, are wonderful by comparison. I believe that independent hydraulics were availble on the Super A.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
