Re: Corn heads: 963 vs. 1063
Posted by Grumpy on November 07, 2006 at 05:37:45 from (208.126.2.182):
In Reply to: Corn heads: 963 vs. 1063 posted by P Backus on November 06, 2006 at 09:03:25:
There was a factory recall on all 900 corn heads. All gear box were sent back to the factory to be rebuilt. The new gear box's had coil springs on the slip clutch just like the 1000 heads. The old box's had belvue springs. Compare the 963 head to the 1063 heads to see if they are the same. This recall was over 20 years ago so I doubt if there are any old gear box's left. Stan
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
