Re: Corn heads: 963 vs. 1063
Posted by P Backus on November 07, 2006 at 06:24:51 from (69.128.33.56):
In Reply to: Re: Corn heads: 963 vs. 1063 posted by Grumpy on November 07, 2006 at 05:37:45:
Thanks for the info. I will look for Bellville washers vs. coil
springs. Presumably if they had that update, they would also
have the updated gears that IaGary was talking about, right?
Would that make the 900 series head the same as or "just as
good" as the 1000 series? This particular one is in nice shape,
just as good as the 1063s that he has there, and I hate to pay
the extra $1500 just to get the extra digit in the model number,
if that"s the only real difference.
Thanks
Paul
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
