Re: Dropping H hydralic Pump
Posted by RustyFarmall on November 07, 2006 at 05:40:53 from (207.32.13.226):
In Reply to: Dropping H hydralic Pump posted by mwilke on November 07, 2006 at 05:29:36:
The belly pump is driven from the counter shaft on the transmission. Pull a couple of cotter pins out of the drive coupling and you can remove the coupling. Unscrew the 3 pipes that extend out through the torque tube, remove the control lever, remove the fill cap, and then you can remove the four bolts that hold the pump in. Be careful, the pump is very heavy and awkward. You need a floor jack and probably a helper.
