Re: Using a newer Crank in a 53' cub
Posted by Jim Becker on November 09, 2006 at 16:03:25 from (71.164.210.94):
In Reply to: Using a newer Crank in a 53' cub posted by Kurt in Va Beach on November 09, 2006 at 09:36:16:
Probably from a power unit, maybe a later tractor. It should work OK. I would set it in place and rotate it to verify clearance between the counterweights and the engine block.
