Re: C farmall
Posted by Wardner on November 09, 2006 at 17:18:06 from (4.154.242.124):
In Reply to: C farmall posted by bm3501466 on November 09, 2006 at 15:01:12:
I like the question and would like to see more of these. This subject is the reason why I have parts books of tractors that I do not own. For instance, I have a 656 book but I doubt if I will ever own the tractor. I assume there must be alot of 300, 330, 340, 350, 460, 504, 606, and others that could use parts from that tractor. The parts could be direct replacements or slightly different to improve operating characteristics for a special application. I did a bunch of gear swapping in a SMTA and now have a tractor with a top speed of 11 mph. 1st gear, low range is around .5 mph at rated rpm.
Getting back to your question, I doubt if a 504 motor(C153) will fit easily into a C. Although the motor uses many of the parts from a C and SC parts book, it is cast with a flange that bolts up to the H derived tractors.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
