Re: Cub, 6v or 12v
Posted by Joe Kimbriel on November 09, 2006 at 17:30:34 from (136.200.52.33):
In Reply to: Cub, 6v or 12v posted by Tom Landefeld on November 09, 2006 at 17:19:04:
Does it run without a battery? Must have a Mag if it does. I guess the thing to do, not knowing much about what you have, is to measure the battery terminals and see if you get about 13 volts or about 7 volts.
