Re: distributor cap bad????
Posted by El Toro on November 09, 2006 at 20:29:00 from (64.12.116.65):
In Reply to: distributor cap bad???? posted by JMM on November 09, 2006 at 19:46:43:
If you have the coil wire going from the coil to the center of the cap you should have fire from your plug wire without connecting it to a sparkplug. I would replace the rotor first. Make sure that rotor is clean. Clean it with some 400 grit wet or dry. Try another plug wire
to see if that's the problem. Hal
