Re: Farmall A Pulley
Posted by Georgia Boy on November 10, 2006 at 10:51:05 from (168.8.170.20):
In Reply to: Farmall A Pulley posted by LA-Man on November 10, 2006 at 05:27:36:
I had to purchase a heavy duty two jaw OTC puller and a large
bearing splitter. Then I used some heat, also. The important thing
to remember is to get the puller completely behind the pulley neck,
as close to the shaft as possible, or you will break off parts of the
flange.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
