Re: distributor cap bad????
Posted by El Toro on November 11, 2006 at 12:21:46 from (64.12.116.65):
In Reply to: distributor cap bad???? posted by JMM on November 09, 2006 at 19:46:43:
Did you find the problem with your ignition? Hal
