Re: 300u Stuck after 1 week!!!
Posted by gene bender on November 12, 2006 at 02:37:24 from (67.55.226.214):
In Reply to: 300u Stuck after 1 week!!! posted by JayWalt on November 11, 2006 at 23:05:32:
The starter drive was locked up. next time you think the engine is froze take starter out and in the process you mite hear it click. mite need to use some light lube on the bendix. this can happen if weak voltage to the starter. clean all terminals and make sure the cables are good 1ga . dont need a gen for a few starts as if the batt is any good it should start many times providing the system is in good shape including starter.
