Re: Farmall MD Hyd. Lift all pump
Posted by gene bender on November 12, 2006 at 02:47:22 from (67.55.226.214):
In Reply to: Farmall MD Hyd. Lift all pump posted by Brad in WI on November 11, 2006 at 21:48:59:
yes as i-h made an assy that went on top of the stand-pipe and with the control lever back and locked you had two-way. Now you can add a two-way control say on the lite bar then run the hy line out the elbow on the right side thru the two-way valve and back to the stand-pipe and with lever pulled back and locked you will have two-way. To run single hy for a loader just un-hook the line that runs to the two-way valve and run the line to the loader cycls. I would put a kwick coulper on the line going to the two-way valve that way when you wanted to use the loader would be easy to hook up.
