Re: Upgrading H and M engines
Posted by riverbend on November 12, 2006 at 10:13:11 from (208.160.33.115):
In Reply to: Upgrading H and M engines posted by Charlie M on November 12, 2006 at 08:39:24:
A lot depends on where you are starting and where you want to go.
When I rebuilt the motor on my H, the biggest increase in compresion came from using a later model gasoline head. Domed pistons added a little too. Having the cam reground to a Super H spec added 0.040" lift ( up from 0.202").
Overall, the compression went from 4.5:1 to 6.25:1 (calculated). It made a big difference in the power output, it was enough that i could feel it. It was not so much that the motor was hard to crank.
Greg
