Re: 130 Axle Leak
Posted by scotty on November 13, 2006 at 09:39:38 from (199.231.49.128):
In Reply to: 130 Axle Leak posted by chad504 on November 13, 2006 at 09:16:03:
Chad, The oil that is leaking onto the brake band is gear lube that traveled from the bull gear to the driven gear then through the seal onto the brake band. You will need that inside seal and you will also need axle bearing retainer seal. Under the bearing retainer is a gasket and another gasket under the dust cap inside the final drive. Oh, and the gasket under the upper pinion cover. Block up the tractor under your final drive. Remove your tire and wheel. Remove the drawbar. Remove the inside final drive cover and remove axle. To change the outside seal, you have to press off the outside bearing. With the axle and bull gear out, remove the fender and then final drive. Replace the seal and brake and replace the assembly. scotty
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
