Re: 130 Axle Leak
Posted by gene bender on November 14, 2006 at 16:15:33 from (67.55.226.214):
In Reply to: Re: 130 Axle Leak posted by scotty on November 13, 2006 at 09:39:38:
scooty you dont need to remove the bearing just remove the brake drum and the bearing and shaft will come out thru the housing after taking off the cover plate holding the bearing in place. The diff shaft only comes out thru that hole.
