Re: Super M 9 speed?
Posted by D Slater on November 13, 2006 at 18:24:52 from (205.188.116.133):
In Reply to: Super M 9 speed? posted by D. Shafer on November 13, 2006 at 15:30:21:
Yes they made it and No, M&W SM fourth speed gears are slower than IH SM fourth. If I remember correct one tooth bigger on 4&5 slider and one tooth smaller on fourth drive gear, 1 through 3 the same. Have numbers here somewhere I could double check. Had 2 at one time but like the regular M gear spread better with 9 speed. Had a SM hiesler 9 speed but was never inside it to check gear counts.
