Re: H rear wheel wobble
Posted by GordoSD on November 14, 2006 at 08:28:34 from (66.115.200.140):
In Reply to: H rear wheel wobble posted by dakotaclassic on November 13, 2006 at 15:08:17:
Not a hard fix at all. Sounds like you caught the inner bearing failure quickly.
Remove PTO and drain the tranny, probe around in there with a magnet on a rod or shaft. Support the bull gear exactly where it is with a piece of cut to fit wood wedge. Pull the axle and replace the bearing/bearings as needed.
Or if you are not too far from Mitchell SD I can help or buy the thing.
Gordo
