Re: Head gasket not sealing, kinda long
Posted by Janicholson on November 14, 2006 at 18:44:12 from (66.173.50.95):
In Reply to: Head gasket not sealing, kinda long posted by Superdave57 on November 14, 2006 at 18:19:29:
Though I don't want to bear bad tidings, I think there may be cracks in the cylinder castings (block) that surround the sleeves. These cracks may be all but invisible, but they would let water in between the sleeve and the block, leaking into the pan. It could also be pinholes or corrosion pits allowing coolant where it should not be. If you are making this fine tractor (I own one)good again, I would pull the sleeves and magniflux the bores. (it is possible to fill the bare block with H2O with dye in it with the head off and sleeves out to use gravity to check for leaks in the casting, but crack detection is preferable. To get H2o comming out of the sleeves in the pan requires the H2O to be where it should never be. The metal to metal seal of the ring on the top of the sleeve stops H2O at that point. If the sleeves are easy to install, and do not require freezing and heating of the block there may be other issues. There are A, B, C, and D bores in blocks sleeves at the factory are/were select fit to these sizes. Standard overhaul kits do not distinguish between them. A and B holes will be OK I think, C and D holes will be loose. The info is stamped next to the hole on the deck of the block. Good luck, and may it be none of the above. JimN
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
