Re: OT-Truck Charging System
Posted by Bob on November 15, 2006 at 06:00:23 from (69.178.229.154):
In Reply to: Re: OT-Truck Charging System posted by silly ole dawg on November 15, 2006 at 05:35:33:
Converting to 12-Volts is EASY.
Likely, the gauges are the "thermal" type, and don't care if they are fed (+) or (-) ground.
Rather than using a resistor to power the gauges, I use a simple 6-Volt "3-terminal regulator", which is the size of your thumbnail, mounted on a little scrap of aluminum, as a heat sink.
Install a 12-Volt alternator, use a resistor with the coil, or replace it with a 12-Volt unit, change out the light bulbs, and heater motor.
Here's a simple way to connect up an alternator:
Or, another, more $$$, more complicated option is to use the series-parallel setup mentioned by the other poster.
