Re: OT-Truck Charging System
Posted by Janicholson on November 15, 2006 at 07:23:42 from (199.17.6.122):
In Reply to: Re: OT-Truck Charging System posted by Michael Sheik on November 15, 2006 at 07:10:14:
No it does not, it is a pto from the trans lay shaft which engages like a sliding gear normally does It cannot be shifted into and out of gear without stopping, but once it is in gear, it will drive the pump when ever the tranny input shaft is turning. (If this wern't the case a dump truck driver would not be able to drive forward while tipping the load higher to spread gravel) It is (with an open center valv,e and the pump running during field operations) the same as operating a letter series belly pump. For operating down the road, I would shut off the PTO to reduce wear and tear on the shafts and pump, and to reduce the chance that operator error would dump the load by moving the wrong lever(never happens), but only because it is conservative to do so. JimN
