Re: Head gasket not sealing, kinda long
Posted by Superdave57 on November 15, 2006 at 17:27:10 from (71.31.215.69):
In Reply to: Head gasket not sealing, kinda long posted by Superdave57 on November 14, 2006 at 18:19:29:
Thanks for the replies. When I pulled the old sleeves out, two years ago they block was fine, there had been no leaks on them. Try as I might, I try to give all circumstances when I post, but I should have added that I can see the anti-freeze on the piston side of the sleeves, which makes me think it is the head/gasket/sleeve seal.
