Where to start troubleshooting
Posted by Mike CA on November 17, 2006 at 09:00:03 from (214.1.211.251):
It may be pointless, but if it's easy I'll give it a shot. I say pointless because I'll be taking it all apart anyway, and probably replacing a good portion of it... but anyway, on to my topic...
My temperature gauge does not work on my '46 H. When the tractor was running for about 5 minutes or so the gauge did not move. Oil pressure gauge read fine, but the Water Temp was dead.
I'm sure there as many things that could be the problem as there are parts that make up the temperature / cooling system. But what is a step-by-step guide that I can start checking that maybe I can find a loose wire, or something easy?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
