Re: Where to start troubleshooting
Posted by RustyFarmall on November 17, 2006 at 09:24:29 from (199.120.81.241):
In Reply to: Where to start troubleshooting posted by Mike CA on November 17, 2006 at 09:00:03:
Your temperature guage is a mechanical unit, no electricity involved. The engine will need to run for much longer than 5 minutes before you will see any movement, and the tractor will actually need to be working before you will see much movement at all. These guages do quit working sometimes, but not very often. If you want to check it, you will need to completely remove it from the tractor, and then drop the sensor end into a pan of boiling water.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
