Re: Farmall A Head Gasket Sealer
Posted by Estle Cloud on November 17, 2006 at 15:18:21 from (68.155.23.220):
In Reply to: Re: Farmall A Head Gasket Sealer posted by Red Dave on November 17, 2006 at 15:09:43:
Thanks for the information. I have installed head gaskets in cars and trucks as well as other make tractors, but that was the first time to encounter this inbstruction.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
