Re: Primer Question
Posted by CNKS on November 20, 2006 at 20:03:18 from (204.249.178.135):
In Reply to: Primer Question posted by trw on November 20, 2006 at 19:44:43:
I don't use Case-IH 2150, if I did I would use epoxy primer on all, and a sandable surfacer or primer surfacer over the epoxy on the sheet metal to assure a smooth finish. Both of those products will cost more than the 2150 itself. But the Case-IH primer is ok. Epoxy adheres to the metal better and is waterproof, thus it gives corrosion protection. Both the epoxy and surfacer are likely compatible with 2150, I can't say for sure because I haven't actually done it. But, I would have no hesitation if I ever decide to use it. As to hardener, don't use it unless you have a supplied air system, a charcoal mask is not adequate protection. The isocyanates in the hardener can make you very sick.
