Re: Primer Question
Posted by CNKS on November 21, 2006 at 07:23:16 from (204.249.178.135):
In Reply to: Re: Primer Question posted by NDS on November 21, 2006 at 06:21:36:
IH did not use primer -- the original alkyd enamel, which is still sold, does not require it. That does not mean the paint will not adhere to the primer better than it does to the metal, though. Modern paints require primer or they will not adhere well. Whether or not 2150 is a "modern" paint is subject to question. It is an "acrylic modified" alkyd enamel, that is it has some acrylic properties. It should be used over primer, that may or may not mean it will fall off without it. But, since priming is the easiest operation of the whole procedure, there is no reason not to use it. The best way is to use epoxy, followed by a sandable surfacer on the sheet metal -- that will produce the smoothest finish.
