1466 Adjustable Front End
Posted by 61-4010 on November 21, 2006 at 19:30:31 from (198.203.175.175):
Hi everyone. Just took receipt of 1466 and I"m SOOOO excited. Looks like I have a little bit of work on her....but overall, she is a nice one.
Have a question, though, regarding the front end. I noticed there is approximately 3/4 inch or more gap where the front pin that holds the axle and the axle itself. There are 3 or 4 large washers on the pin but still a good sized gap between the axle and where the axle is held on via the pin (hope this makes sense). I"m not familiar with the 1466 front end and not sure if this is normal or not.
So if any of you have some pictures that you could take of your 1466 (or similar) front end, I"d love to have them for a reference point.
Thanks!
