Re: 1466 Adjustable Front End
Posted by Brownie 45 on November 22, 2006 at 03:57:06 from (207.177.82.47):
In Reply to: 1466 Adjustable Front End posted by 61-4010 on November 21, 2006 at 19:30:31:
Probably got too much grease. Check the toe on the front end when you are through with the shims. Toe in of 1/8 to 3/16 will make it steer very well.
