Re: Hydraulic Control Valve
Posted by Jaywalt on November 22, 2006 at 07:38:59 from (24.223.138.48):
In Reply to: Hydraulic Control Valve posted by Triker on November 22, 2006 at 06:55:56:
That depends. How many sets of cylinders (plumbed in parallel if for lift arms, dumps etc) does the tractor have. you need one valve for each set of cylinders That work together. I have one hitch cylinder, 2 lift cylinders and 2 dump cylinders. I only have 2 valves, so I am using 2 "valve selectors" to select between the dump cylinders and the rear hitch. It all depends on your setup, pics would be helpful as well.
