Re: Farmall C trouble
Posted by scotty on November 22, 2006 at 11:07:05 from (199.231.49.128):
In Reply to: Re: Farmall C trouble posted by IHC-Farmall on November 22, 2006 at 10:22:03:
You need to drain the touch control,pull the hydraulic lines off, remove the pump and seperate the assembly. The seal is an o-ring that rides on the driven pump shaft, The o-ring is available from Case IH. I also have another supplier if they dont want to be bothered.
Gordon Rubber & Packing Co Inc. Derby, Ct 203-734-7152
Good Luck!
scotty
