Re: 140 farmall wiring
Posted by JMOR on April 11, 2009 at 20:08:59 from (72.181.158.237):
In Reply to: 140 farmall wiring posted by Farmall Bob on April 11, 2009 at 19:19:30:
Yes, the problem is that the field 's full current is over 3 amps & your bulb may supply about 0.2 amps. It doesn't need to supply the full 3, but GM in all their wisdom? decided on about 1 amp, so you are way short, hence the 10 ohm resistor.
third party image
This post was edited by JMOR at 20:17:07 04/11/09.
