140 farmall wiring
Posted by 69fastback393 on April 11, 2009 at 19:19:30 from (67.209.4.39):
i did complete rewire on my 140 farmall today everything came out great except its not charging.
i used the warning light method (#1815 bulb) instead of a diode.what i have found out is when i bypass the light by connecting the 2 light wires together it works.
can i jump a diode across the 2 light terminals and make it work?
has anyone ran into this before? where do i by these diodes?.....thanks
