Re: Int'l 966 Hydro Will Not Move
Posted by Marvin on November 22, 2006 at 17:36:47 from (66.82.9.54):
In Reply to: Re: Int'l 966 Hydro Will Not Move posted by Allan In NE on November 22, 2006 at 06:08:43:
Thanks for your input. I had rebuilt the hydro from front to back and from top to bottom. Yes, I isolated the tubes coming out of the transmission. The tractor is extremely strong when it does work right-- in forward and reverse. I already know that the problem is inside. I'm not sure if it is one of the check valves in the charge manifold or the shuttle valve. My charge pump pressure is excellent and my servo pressure is excellent. Charge pump pressure is okay even at 5000 PSI in forward or in reverse.
