Re: Tuning a carb????
Posted by Allan In NE on November 23, 2006 at 05:49:21 from (148.78.243.24):
In Reply to: Tuning a carb???? posted by IaGary on November 23, 2006 at 04:51:08:
Hey Gary,
Hold it a minute!
Before you start goosin' that carb, remember that with these old gassers, the wear point is that rubbin' block on the points. The block wears and the points tend to close up. For every one degree of dwell change, the timing is likewise changed 3 degrees.
Rule of thumb is, make darned sure all other systems are up to snuff before fiddlin' with the carb.
Maybe your sputterin' tractor is just trying to tell you that it is time for the yearly tune up?
Allan
