Re: Steering on an A
Posted by Brownie 45 on November 23, 2006 at 07:11:39 from (207.177.82.245):
In Reply to: Steering on an A posted by Roger Mills on November 23, 2006 at 06:48:30:
If the steering arm which comes out of the gear box has a square which mates with the shaft coming out of the gear box & tightens with a 3/8 's bolt, see if there is slop or looseness at this point. If you can't tighten this bolt further, you can remove a small amount from one side of the arm with a hacksaw to let the bolt tighten up better. If the arm is the later style, this method won't work. If all is tight in the steering arm department, you will have to get into the steering box & see what it needs.
