Re: Super C power--gene bender?
Posted by gene bender on November 23, 2006 at 10:30:10 from (67.55.226.214):
In Reply to: Super C power--gene bender? posted by Chris from Wa on November 23, 2006 at 09:10:36:
Yes go to the fire craters and 3 1/8 bore. HI-DOMES are also good. I think the FIRCRATERS mite have a little more power. If you have a ZENITH you can get a next size larger jet for the carb. Dennys will have them. There is a # on the jet or you can drill it out a few thous larger. The DIST will give you advance curve. A mag will go to 33 advance as soon as it starts. If you go to the dist mite be good if you can find someone with a strob to check the curve and make sure it works fine.
