how to put on decals
Posted by 51Hwf on November 24, 2006 at 20:47:40 from (4.158.198.199):
I just finished my first tractor paint job today. Now the next thing is putting on the decals. I'm not sure what kind I have or how to put them on. The package didn't have any instuctions. It just says IHCH replacement decal set and I paid about twenty bucks for them. Thats as much of a decription as I can give. Anyway, do I have to put them in water and wetten the surface or just peel off the backing and stick them on? Also does the clear part between the letters stay on the tractor or does that part peel away after its applied? Any other hints would be helpful. thanks
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
