Re: how to put on decals
Posted by RustyFarmall on November 25, 2006 at 06:05:53 from (207.32.13.235):
In Reply to: how to put on decals posted by 51Hwf on November 24, 2006 at 20:47:40:
Yes, they need to be soaked in water until the backing peels off easily. Sometimes they need to soak for a long time, other times a short time will do it. Also, the surface where the decal is to be applied needs to be sprayed liberally with windex. This will allow you to slide the decal around a bit to get it in the correct position. Once the decal is in position, use a soft cloth or squeegee to work the air bubbles out. Work from the center of the decal to the outside. If a bubble shows up after you thought you were done, just prick the bubble with a small pin or make a small cut with a razor blade to get the air out.
Here's a hint, do not attempt applying the decal wothout the windex, the decal will immediately stick, and you will not remove it without damage.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
