Re: sulfated batteries
Posted by Paul in Western WI on November 25, 2006 at 05:40:37 from (70.41.10.82):
In Reply to: sulfated batteries posted by whiskeyriver on November 24, 2006 at 22:32:40:
"i have good trickle charge battery tenders for my 12v tractors "
Are you using a auto trickle charger? If not you are over charging the batterys. I take care of cell tower sites and we control the voltage real close on all of our batterys. we get 3-6 years from them. Heat will take a battery out real fast also.
