Re: sulfated batteries
Posted by WhiskeyRiver on November 25, 2006 at 20:56:30 from (71.124.45.112):
In Reply to: Re: sulfated batteries posted by Paul in Western WI on November 25, 2006 at 05:40:37:
First, thank you all for the large amount of advice. To answer a few questions, yes, the trickle charger i use is made by MAC which is the same we use where I work and is approved to be used with our MSD ignitions and ECM's The tractor i have the most problem with is a 1939 H which is still on 6V. i use it mainly for pullin a hay rake once or twice a summer and a few shows here and there. The batteries ive been purchasing are napa commercial, and only make it a couple of years befor they show dead cells. Thanks. Adam
