Re: Correct Cub front knuckles
Posted by CNKS on November 25, 2006 at 08:56:43 from (204.249.178.135):
In Reply to: Correct Cub front knuckles posted by 2nTim on November 25, 2006 at 08:28:10:
Unless there is a serial break listed in your catalog, they are both correct. IH used at least two suppliers for many of the steering parts, thus the different part numbers. If you will look closely at yours and the illustrations, you should be able to tell which ones you have. Since you likely have to go to the aftermarket for them, that does not mean they are available, but others should interchange.
