Re: Farmall H Rear Wheel Bearing
Posted by Nebraska Kirk on November 26, 2006 at 18:53:05 from (207.91.30.34):
In Reply to: Farmall H Rear Wheel Bearing posted by Rundm on November 26, 2006 at 15:21:10:
Paul has it right, however, I would not remove the top cover just to remove the bolt holding the bull gear on the axle. Instead, remove the PTO and then reach through the PTO hole and unscrew that bolt. The same thing is accomplished, but with not as much work, in my oppinion.
