Re: Farmall H Rear Wheel Bearing
Posted by Theman on November 27, 2006 at 13:44:22 from (65.248.77.5):
In Reply to: Re: Farmall H Rear Wheel Bearing posted by Nebraska Kirk on November 26, 2006 at 18:53:05:
To add further to Kirk's comment, place a wood block between the bull gear cap screws and 'jack' the axle out of the housing as you back the screw out. Speaking of blocks, wedge the bull gear up into place before removing the axle because it's heavy and very difficult to hold up while re-assembling.
