Re: Correct Cub front knuckles
Posted by Roger46 on November 26, 2006 at 19:43:15 from (69.58.159.58):
In Reply to: Correct Cub front knuckles posted by 2nTim on November 25, 2006 at 08:28:10:
Tim, That must have been a common thing to do. I bought a Cub several years ago and just finished restoring it. The previous owner had also welded mine (didn't notice when I bought the tractor). It is a job cutting them off as you need to sawzall through the steering arms far enough until you cut through the shaft. Mine is a 1947 and I replaced them with the coarse thread screws. It can be expensive I found out as you need replacement spindles and steering arms (right and left hand). Good luck. Roger
