Re: 460 carb is frosting up
Posted by old on November 27, 2006 at 21:11:06 from (4.244.90.73):
In Reply to: 460 carb is frosting up posted by Dan (wi) on November 27, 2006 at 18:27:14:
As Scott says its normal part of life and ALL engine do it, you just don't see it on cars/trucks. Thats why on cars and truck theres a tube that runs off the exhaust manifold going to the air cleaner to heat the carb intake air
